Unlock Bios Password la-l242p clear me region
helmi h
test the original of my PC Dell vostro 15 3510 gdm51 la l242p rev 1.0 (a00)​
its your bin file the pc no longer starts
  • clear me.zip
  • Dell vostro 15 3510 update.zip
helmi h
check hardware
no the problem is not in the hardware because the machine has the first time it displays with bios password, and there is someone who flashes the bios is it gives the same problem sa (just gives yellow then green then white colors) danc the problem
helmi h
check hardware
no the problem is not in the hardware because the machine has the first time it displays with bios password, and there is someone who flashes the bios is it gives the same problem sa (just gives yellow then green then white colors) danc the problem in the bin
same problem with new file means problem is not bios
the problem in the new bin you have to clear me region for it to work well, if you want I gave the original bios bin to repair
  • clear me.zip
