program both bios and ecNeed help to remove password from bios. Thanks.
sn:5CD231FWH9
MAINBOARD : DAX8SFMB8B1 Rev-B
MODEL:X8SG
EQUIPO DA VIDEO PERO VUELVE A PEDIR CONTRASEÑA NO ME DEJA INGRESAR CON F10 EN EL PRIMER ARRANQUEAt 1st boot press F10 and RESET BIOS to factory defaults, save, restart and password will go on. After that enter in bios setup and in Main tab you have "set machine unique data" and write there what it's written on the label inside the cover. Or extract DMI from your bios dump:
Feature Byte: 476J6S6b7B7J7M7Q7W7saQapaqauawbUbhcAdpdqeTfPguk8mEmwn7nVpFpTpqqjqz.4r (no spaces)
Serial: 5CD228H508
SKU: 6J3K6EC#ABF
Build ID: 22WWRTCT601#SABF#DABF
Board CT: PQMAN038JGV0CM
Name: HP ProBook 440 G9
Save and use BCU to exit MPM mode or restart laptop/desktop how many times counter shows.
REMOVE CMOS BATTERY BEFORE WRITING BIOS
At 1st boot press F10 and RESET BIOS to factory defaults, save, restart and password will go on. After that enter in bios setup and in Main tab you have "set machine unique data" and write there what it's written on the label inside the cover. Or extract DMI from your bios dump:EQUIPO DA VIDEO PERO VUELVE A PEDIR CONTRASEÑA NO ME DEJA INGRESAR CON F10 EN EL PRIMER ARRANQUE
i need such to unlock Elitebook 860 G10At 1st boot press F10 and RESET BIOS to factory defaults, save, restart and password will go on. After that enter in bios setup and in Main tab you have "set machine unique data" and write there what it's written on the label inside the cover. Or extract DMI from your bios dump:
Serial: 5CD2489L36
SKU: 6C5X2LT#ABF
Nassim I , Vahab Hemmati , Djontkachuk , Dcomp , webnetsolution , umair nadeem , Electronica360 , Ali Shaikh , user46647 , destinycenter , oscarsgcs , MafiGeeks , buynnex , Hardyk2003 , Yonas-bole , jepyawaz , igiteam , user6389 , M-Francis , Bruno722 , jimghonum , ELEVETUS TECH , shanghaii , user50996 , jasheerkkv , ice99999 , touqeer165 , alexey206 , user10018 , maggerme , shibuya1977 , user47831 , banofils , alambd4356 , CanaanManyatsi , gullu , ozgurdegerli , demonbreack , user57834
